replacing brake lines?
Old Oct 6, 2005 | 03:51 PM
oc9crx's Avatar
oc9crx
Default replacing brake lines?
I just got new brake lines, rotors, pads, and calipers for my 88 crx si. I was wondering what is the procedure with the brake fluid, do you bleed it all out or what?
Old Oct 24, 2005 | 06:55 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
bleed it all out, and then you have to fill up the system, and then individually bleed each caliper and drum. There is a specially criss cross patern to do it in. It should be online. Jsut search the forum.
