test the cooling fan?
Old Oct 6, 2005 | 01:14 PM
Magic Carpet's Avatar
Magic Carpet
If you got em, burn em!
Default test the cooling fan?
is there a way to test the cooling fan to see if it works, rather than like totally cutting the wires to it and putting power to it. i havent seen or heard it turn on since i rebuilt the motor.
Old Oct 6, 2005 | 01:57 PM
Exempt's Avatar
Exempt
2 tone Rex
You can find the connector, and just use a paper clip and jump the 2 wires together... With the key on ofcourse...
Old Oct 6, 2005 | 02:00 PM
boriblanco's Avatar
boriblanco
the clip is on distributer side kinda under it to the left
Old Oct 6, 2005 | 06:45 PM
Magic Carpet
thanx
Old Oct 6, 2005 | 07:21 PM
jlicrx's Avatar
jlicrx
the cooling fan switch is on the back of the block right next to the oil filter - 2 wire connector with big round black rubber boot - pull boot off of sensor and touch the 2 wires together with key on - fan should come on - when putting the wires back on the sensor, it doesn't matter which one is on which post - it is just a switch - if fan comes on, the switch is probably bad - if fan still doesn't come in, you need to check the fan relay which is on the passenger side fender well, right behind the headlight
