Header Leak Question
Old Oct 4, 2005 | 06:41 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Default Header Leak Question
My header is leaking, because I see the oil on it from the head, and when some of the oil gets on it it burns off and smokes outa my hood. I replaced the gasket with a new one. The old one had a single piece of metall and the new one has two pieces, but for some reason it is still leaking. Should I put High heat silsone around it?
Old Oct 5, 2005 | 06:24 AM
Magic Carpet's Avatar
Magic Carpet
If you got em, burn em!
my friend welded a hole shut on his header, im not sure if that is a good idea or not but it worked.
Old Oct 5, 2005 | 07:24 AM
Tankard's Avatar
Tankard
Are you sure it's not the valve cover gasket that's leaking on it? My header had a hole in it and it made a loud ticking noise. You'll know if your header is leaking becasue of the sound. Also, no oil comes out of a hole in the header. That's why i'm thinking your valve cover gasket may be leaking oil onto it.
Old Oct 6, 2005 | 07:50 PM
VTEC-Power's Avatar
VTEC-Power
I had a tear in my valve cover gasket and it started spraying oil all over the engine bay, so thats why i would say valve cover gasket also
Old Oct 7, 2005 | 10:22 AM
screaminhonda's Avatar
screaminhonda
what side is it leaking on cuz right now my ZC is leaking from the cam seal, even though it looks like its from the head or valve cover.
