D16A9 rebuilding
I just bought a D16A9 for my '90 DX. The engine is an EDM D 1.6 DOHC NON-VTEC. It produces 130HP stock. I know you guys don't get this engine in USA, but i was wondering if anyone knows if i could use replacement parts off of D16A6 (or any other engine) for it? Like piston rings, bearings, valves, valve guides...?
Engine needs rebuilding, and i was thinking of ordering parts from USA (since everything is so damn expensive here in Croatia), but i need to know if any parts are interchangeable.
Thanks for any help!
If anyone is still wondering, i found this page (http://www.quickhonda.net/zc3.htm) that explains what parts from other cars can be used on ZC.
And they said D16A9 is a europian version of ZC.
I have another question.
Main bearings spun on this engine. Engine can still run, but i prefer not turning it on because i fear something else might get damaged. Could crankshaft have received some damage? Once i take the crankshaft out, how do i inspect it for damage? Should i look for any other signs of damage on some other parts?
Hey!
I was also checking for what parts to buy...and on that webpage: http://www.quickhonda.net/zc3.htm it says that engine is mostly the same as 1989 integra...and that integra has D16A1 engine, so i suppose D16A9 is the same as D16A1, or mostly the same.....
D16A6 i think it has weaker piston rods bearings...
I dont know what to order
Did anybody did that and knows which statement is correct.?
Thank you
Thank you
Hello,
Easy suspension tuning is in your hands. S - Tech was made so that everyone can enjoy sports driving. TEIN based these springs on original specification so that the installation is easy. Full compliance with car inspection, and great styling. Adding some more exicitement to your ride.. The highest quality brought to you at great JayDM prices. Now comes in two types to choose from.
