91 civic problems
Old Aug 20, 2005 | 07:49 PM
namecaps's Avatar
namecaps
Default 91 civic problems
i just put in the same honda civic 1.5 motor as i pulled out because of a blown rod. i swapt over all of the bolt on things and now when i start the car it surges real bad i dont know what the heck is wrong with it
Old Aug 20, 2005 | 08:45 PM
90sicivic's Avatar
90sicivic
ACCORD & CIVIC TUNER
what kinda surges?... like as in.. running real rough?... or what?.. i mean there is a ton of things that can happen.. when you do a swap.. even if it is the same exact engine that was in there b4... so explain what it is doing a lil better.. and maybe some of us can help you!
You woulda been better off going with the d16a6... prolly only woulda ran ya.. like 150 bucks.. and the engine that you got .. mmh.. d15b??? maybe.. i think..
neway..
yea
bryan
Old Aug 22, 2005 | 12:42 PM
namecaps's Avatar
namecaps
yeah but i got the engine for only 50 bucks cause my friend did a swap on his car but whne i turn the car on it runs real ruff it surges like the rpms are goin high to low constantly the ecu only flashes once when i turn the key, the eughast was i guess red hot when i firts turned it on when it was surging i just dont know what the problem is
Old Aug 22, 2005 | 01:01 PM
DirtyHarry's Avatar
DirtyHarry
one flash on the ecu is oxygen sensor, surge in idle is the idle air control valve. thats on the right side of intake mani if looking down from the front of engine. could be a vacuum hose also. the idle control valve has a few small hoses coming out of it and has a cylinder looking shape. It sits right next to the intake mani, or the throttle body. I've heard of cleaning it with brake cleaner inside and out, but i never tried it.
Old Aug 22, 2005 | 09:18 PM
Magic Carpet's Avatar
Magic Carpet
If you got em, burn em!
idle air control valve isnt throttle position censor is it, cause that could be a problem, also the vacuum lines make sense.
Old Aug 23, 2005 | 03:33 PM
DirtyHarry's Avatar
DirtyHarry
Default different
yep, they are different.
