Radiator Fan
Right now im going through the loose unconnected wires left on my hatchback from the careless previous owner. There was a manual fan switch made to the fan as a quick fix. Now in the Haynes manual it says theres suppose to be a thermal fan sensor near the lower radiator hose (sensor socket doesn't exist on this radiator), but if theres no thermal sensor, there shouldn't be a thermal fan switch right? I found a loose socket that would fit into the fan socket, Blue wire/Yellow on Black wire. I've tried running it with this connection but it doesn't active the fan at all. Anyone have any suggestions?
