sohc vtec ecu!!!!
Old Jul 31, 2005 | 04:06 PM
jdmc-rex909's Avatar
jdmc-rex909
Default sohc vtec ecu!!!!
im doing a mini me swap i have a sohc zc motor and a d16y8 head i need a vtec ecu which ecu do i need? p28? p72? obd0? obd1? please help me folks thanks
Old Aug 1, 2005 | 12:11 AM
Exempt's Avatar
Exempt
2 tone Rex
P28 is probably the best to run on that combo, and switch to OBD1... U dont even want to mess with OBD2...
Old Aug 1, 2005 | 10:43 AM
CR-X 88 1stGen's Avatar
CR-X 88 1stGen
BLOW OFF VALVES RULE
i did the swap you need to p28 ecu .......
Old Aug 1, 2005 | 03:58 PM
jdmc-rex909
so all need is p28? cool thanks guys
Old Aug 1, 2005 | 04:02 PM
teg92's Avatar
teg92
WHAT OK YEAH!
what kind of car is it going in?
Old Aug 1, 2005 | 06:24 PM
jdmc-rex909
a crx 89 si
Old Aug 1, 2005 | 08:47 PM
Exempt's Avatar
Exempt
2 tone Rex
Youll need a P28, and a preOBD to OBD1 conversion harness... Unless you want to wire all that yourself, which isnt fun...
I got my harness from here:
http://www.rywire.com
Old Aug 1, 2005 | 08:48 PM
95civicex4dr's Avatar
95civicex4dr
JHMEH9
p28 comes stock with d16z6
Old Aug 7, 2005 | 02:11 PM
jdmc-rex909
p28 has different harness dont i need a pr3?
Old Aug 8, 2005 | 12:23 PM
Exempt's Avatar
Exempt
2 tone Rex
Youll need to either wire up OBD1, or get a preOBD to OBD1 conversion harness to run the P28...
The PR3 is for a B16 preOBD engine, and will look for things your engine dosnt have, such as the knock sensor, secondary O2 sensor,ect... So the PR3 wont work without modification... The P28 is the best way to run that head on that block...
