Sri Help
Old Jun 26, 2005 | 11:52 AM
Roli's Avatar
Roli
Default Sri Help
I got a 91 civic dx and i got a free sri from a friend and i want to know where the bracket goes to support the filter.
Old Jun 26, 2005 | 01:23 PM
Exempt's Avatar
Exempt
2 tone Rex
I never even hooked mine up... As long as it dosnt touch the positive battery terminal, you should be fine...
Old Jun 26, 2005 | 05:07 PM
Kai's Avatar
Kai
Rotorphile.
The bracket should be pretty obvious. If it isn't, you may have the wrong intake.
Zip ties are your friend.
Old Jun 26, 2005 | 09:08 PM
Roli's Avatar
Roli
what do i do with the existing hose that went from the old filter to the valve cover? It's in the way and i cant take it off it is connected to another hose????
Old Jun 26, 2005 | 09:32 PM
Kai's Avatar
Kai
Rotorphile.
Throw it out.
That's the PCV line, connect it to the new intake. If the new intake doesn't have a bung for it, it's a peice of crap.
You're making this way more difficult then it really is.
Old Jun 27, 2005 | 07:34 AM
ED9man's Avatar
ED9man
driver
Originally Posted by Kai
Throw it out.That's the PCV line, connect it to the new intake. If the new intake doesn't have a bung for it, it's a peice of crap.
:lmao: :lmao:
Old Jun 28, 2005 | 10:02 AM
Exempt's Avatar
Exempt
2 tone Rex
I came across that problem as well when I was installing mine... I had thought about cutting that metal bracket that held the 2 hoses together, but decided to just push the metal peice under my intake and it was fine like that untill I cut the ends off with a dremel...
Old Jun 28, 2005 | 08:12 PM
Roli's Avatar
Roli
Thanks man, that helps
