help/ urgent, can't get my trany back in
Old Sep 1, 2002 | 03:48 PM
thorbeast's Avatar
thorbeast
Default help/ urgent, can't get my trany back in
I took out my trany on my 91 civic hatch back, I put a new one in but I can't get the shaft in to the engine, thought the cluch plate. the splines seem to be lined up but I still need to push the trany over about a nother inch or so.
Does any one know any thing about this? Do I need to press the trany in or something. The trany is the same one as my old one, So it should fit
Old Sep 1, 2002 | 04:59 PM
WhiteRice's Avatar
WhiteRice
ALl the splines line up!? Did you use your clutch allignment tool? If everything lines up, you should be able to rock it right in.
Old Sep 4, 2002 | 10:33 AM
IrradiatedKitty's Avatar
IrradiatedKitty
weird... trannys can be a ***** to get in, but i've never helped with one that *wouldn't* go in. i don't know enough to help you out.. good luck though
Old Sep 4, 2002 | 05:41 PM
jaje's Avatar
jaje
HC Racer H5
either you haven't properly gotten the clutch alignment tool in or the tranny you are trying to put in may have a different spline size or count preventing you from getting it to fit
here is a list of flywheel/clutch/spline size & count
Old Sep 5, 2002 | 08:12 AM
ls/vtec-crx's Avatar
ls/vtec-crx
You should check if the clutch is aligned properly and if it is check to see if you have the same amount of splines of the clutch. (Count amount of splines.) If it is right get some one turn the crank pulley counter clock-wise while you wiggle the tranny on.
Old Sep 5, 2002 | 03:02 PM
thorbeast's Avatar
thorbeast
well with the info you every one has given me, I realize I am trying to put an 88 trany in a 91 civic. if I buy a 88 clutch plate will it fit on the 91 fly wheel or do I have to do something with that too. Do I have to find a 90-91 trany or can I use what I have?
Old Sep 6, 2002 | 03:36 PM
jaje's Avatar
jaje
HC Racer H5
you can use what you have but you'll need the whole setup from the 88...including flywheel (all 88-91 flywheels will bolt on) and clutch kit...it'll work then...if you try to use a different flywheel you may have to have a maching shop resurface it to work properly
1stgen does lots of work in this area...so he help you wtih that
Old Sep 8, 2002 | 11:07 AM
thorbeast's Avatar
thorbeast
hey thanks for all the help! I finally found the right stuff I was looking for. I had look through a hole lot of junk yards but it is worth it. I found all sorts of stuff including one of those first honda's in the us, the ones with a motor cycle engine. wasn't much left to it.
thanks again for the help
bmxboi23
Accord
Dec 6, 2005 03:35 PM
99Accolude
Accord
Feb 21, 2005 04:05 AM
ROMEO4U
CRX & Pre 92 Civic
7
Dec 31, 2004 03:56 PM
Armadillo
Engine Swaps, Tech & Tuning
4
Sep 9, 2002 06:14 PM
thorbeast
CRX & Pre 92 Civic
2
Aug 21, 2002 03:19 PM
