JDM on USDM...?
Old Jun 8, 2005 | 09:25 PM
shady visions's Avatar
shady visions
Default JDM on USDM...?
I've read several threads and some users seem to be worried that the JDM part won't fit on their USDM car.
How can you tell? Is there some type of list?
Also, I need to know if these JDM doors will fit on my USDM 1990 CRX SI.
http://www.passwordjdm.com/product.a...=all&PT_ID=all
Old Jun 8, 2005 | 09:48 PM
VTEC-Power's Avatar
VTEC-Power
they should fit
Old Jun 8, 2005 | 09:49 PM
VTEC-Power's Avatar
VTEC-Power
I can't gurantee you they will all fit, but a lot should
Old Jun 9, 2005 | 06:10 AM
OneslowredHB's Avatar
OneslowredHB
18 sec beast!
Like he said most everything should fit.
Old Jun 22, 2005 | 12:05 PM
mistacee's Avatar
mistacee
Zc powered ED9
Doors should fit.
Mixing JDM front end parts with USDM parts i am not sure.
mistacee's Avatar
mistacee
Zc powered ED9
When i say mixing JDM Front end parts with USDM parts i mean,
Can u put JDM crx Headlights w/corner lights on a USDM Crx without doing the entire JDM front end conversion?
Old Jun 22, 2005 | 12:55 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
doors will fit. but why pay 500 bucks for used doors? thats ridiculous. your local junkyard would probably be a lot cheaper.
you can put the JDM CRX ZC headlights and corner lights. The sleeker looking SiR lights will not fit.
Old Jun 22, 2005 | 12:56 PM
mistacee's Avatar
mistacee
Zc powered ED9
Post pics or links.
What are the differences between the Zc headlights and SIR's?
Old Jun 22, 2005 | 05:18 PM
Exempt's Avatar
Exempt
2 tone Rex
The ZC headlights are almost identical to the USDM headlights, except I think they are plastic (which id rather have glass)... But they look exactly the same, and fit the same... Edit: And they only have one bulb compared the US, has a high and low beam... (forgot to add that)
The SiR headlights are wider and taller (for the hood that makes room for the B16)...
SiR front end:
http://www.passwordjdm.com/uploads/i..._large/345.jpg
And in 90-91, all JDM CR-Xs had the SiR front ends... So the ZCs only come with a 88-89 bracket which is different than the 90-91 USDM bracket...
