B16a0 = codes 43 & 44 (Engine light lit)
Old Jun 6, 2005 | 01:47 PM
harryr34's Avatar
harryr34
Default B16a0 = codes 43 & 44 (Engine light lit)
What could cause this problem, i have very lumpy and erratic idling.
The car has been parked up for three years, alot of black carbon deposits come out the exhaust,
What do i check/do first?
Thanks
Harry
Old Jun 6, 2005 | 07:09 PM
DirtyHarry's Avatar
DirtyHarry
Default fuel supply
well, code 43 is fuel supply so heres what I think would be wrong, but I'm new so I don't know shit.
1) fuel injector
2) injector resistor
3) contaminated fuel, rusty gas tank, dirty gas tank,
4)fuel pump/relay
Old Jun 6, 2005 | 07:35 PM
jlicrx's Avatar
jlicrx
Thanks
Harry
replace the fuel pressure regulator - after sitting for a long time, the regulator sticks shut and doesn't return fuel to the tank, just dumps it all into the engine - also a very common problem on engines shipped in from Japan, since they have been sitting unused for quite a while
Old Jun 7, 2005 | 02:24 AM
harryr34's Avatar
harryr34
i have taken off the fuel pressure regulator and i sprayed it with wd40 to loosen it up, i am going to check the injectors later, where is the fuel filter located?
Old Jun 7, 2005 | 01:52 PM
DirtyHarry's Avatar
DirtyHarry
Default fuel filter
fuel filter is on the passenger side of the car. next to this black cylinder shaped apparatus with a couple of vacuum hoses coming out of it. The fuel filter has two fuel lines coming out of the top of the filter. Its black also. Heres is a link so you can check with everything you need to know. Its a free manuel for your civic. or what ever you drive. just type this in your search for google or msn, or wherever, just not the search at the top here.
http://tech.hybridgarage.com/tech/
Old Jun 11, 2005 | 02:18 PM
harryr34's Avatar
harryr34
i changed the fuel filter and new plugs, it ran perfect (as new) for about half an hour and then it went back to its normal bad self, i checked the injectors they are working fine, what else can i check, how do i check the o2 sensor?
Old Jun 11, 2005 | 07:24 PM
DirtyHarry's Avatar
DirtyHarry
Default fuel
drain the gas tank out. There is a section in that manual for that. Well, its to remove the tank, but, you have to drain it out first. See what color the gas is.
Old Jun 12, 2005 | 01:37 AM
harryr34's Avatar
harryr34
i will try that today, ma car is running eich and is misfiring
Old Jun 12, 2005 | 01:43 PM
DirtyHarry's Avatar
DirtyHarry
Default check the rotor
Also, you should change the distrib cap and rotor. Make sure the timing is right.
Use the the link for the book as a reference. The o2 makes the car run rich so maybe the o2 needs replace. Its a bitch to do. I changed mine by unbolting the header on top and bottom to move it around a little. I didint take it out though.
Old Jun 14, 2005 | 08:58 PM
flatliner's Avatar
flatliner
Fix It
silly. dont park a car that long. Change the fuel, oil and plugs, IAC ,o2 and most all the seals. parking that long=death.
