abs brakes
When did Honda start using ABS brake systems? I obtained rear disc hubs for converting drums on a 91 civic hatch (std). I was informed they were from a 91 CRX si. One hub was bad inside. The ball bearings had grooved the race.
I went to get a replacement hub (fm 513035) and the shaft orifice was too small. My original hubs had the ABS gear which I removed. Now, after removing the ABS gears, I'm thinking maybe the original hubs aren't from a 91 CRX?? Was ABS available in the 91 CRX si??
PS A new replacement hub is coming on monday based on the "NTN" hub number from the old hub. I'm sure it will work. This is strange because the trailing arm and LCA look the same as the CRX pictures.
Originally Posted by ED9man
No ABS in EF's, at least not in this country.
IBdeletethisthread.
IBdeletethisthread.
