How many more mods can I go?????
Old 04-01-2005, 10:27 PM
99teggsr
99teggsr's Avatar
derrr, i forgot. Get a SAFC, its just like the vafc but no vtec controller. just a mediocre way of tuning, like any piggyback.
99teggsr is offline
Old 04-01-2005, 11:01 PM
Kai
Rotorphile.
Kai's Avatar
Originally Posted by StreetRacingCRX
The VAFC is for VTEC though
That doesn't matter. The V-AFC is an S-AFC already set up for Honda engines, plus a VTEC controller. If you ignore the VTEC controller, you still have an S-AFC that you don't have to configure since the S-AFC is designed to work with most MAF/AFM/MAP systems while the V-AFC is configured for Honda MAP (speed/density) systems.
Tuning the fuel map to your modifications will give you a much better horsepower-per-dollar gain then any other modification you can do now. Add to that camshaft gear timing, and you could gain more. And adjustable cam gear means nothing if you don't dyno tune it.
Kai is offline
Old 04-02-2005, 07:59 AM
StreetRacingCRX
None
StreetRacingCRX's Avatar
My cam gear is adjusted, I will probabally get a fuel regulator and raise the psi
StreetRacingCRX is offline
Old 04-02-2005, 10:36 AM
Kai
Rotorphile.
Kai's Avatar
...which means nothing without proper tuning.
Kai is offline
Old 04-02-2005, 11:05 AM
Snoopy
been there done that
Snoopy's Avatar
more fuel without more air is pointless
Snoopy is offline
Old 04-02-2005, 11:10 AM
TeHJuSTiN
NAM #0001
TeHJuSTiN's Avatar
I'm not even sure which 'Japenese' engine you have?
TeHJuSTiN is offline
Old 04-04-2005, 06:29 PM
1fasthb
1fasthb's Avatar
I will beat a Civic Si and a GSR and keep right up with an Integra Type R and I want to be able to beat it. I am will to spend $1000 but I really dont want to swap or turbo/supercharge it. I don't think ZC pistons will do that much for me. The performance chip is a Skunk2 ECU Chip
DOHC ZC pistons will bump up your compression to about 11:2:1. Saying higher compression means more hp. Also get a skunk2 manifold with a hondata gasket.
1fasthb is offline
Old 04-04-2005, 07:22 PM
StreetRacingCRX
None
I just got a valve adjustment 8:16 and just bought a JUN Racing ECU
Old 04-04-2005, 08:55 PM
ullerw
rexerk
ullerw's Avatar
try individual throttle bodies rather than one, while not always the best way and definetely the more difficult way, with proper tuning it will give u the most power as you get a lot more volume of air
ullerw is offline
Old 04-04-2005, 08:58 PM
ullerw
rexerk
ullerw's Avatar
not too mention im sure there are many suspension things to do such as all polyurethane bushings, new struts, u could throw in a cage for chassis rigidity, front and rear strut tower bars i dunno if you already have them?
ullerw is offline
