Car almost/does die when reving?
warm butter on toast
Yea, my car almost/does die when I rev my engine, then has a hard time starting. Anyone know what this is?
Edit~ Uh..it kinda just went away...
I had the same problem, what you have to do is go onto your throttle body, and adjsut the idle screw, and tighten up your throttle cable. Once you fix the idle screw you should be able to rev it as high as you want and then it will drop back to normal operating RPM.
