Need help with TPS and knock sensor!!!!!!
I have a B16 in my CRX, and I have a TPS code (7) coming up on my ecu along with the knock sensor code (23)
. My engine's idle tends to jump when the engine is warm. It will stop as soon as I disconnect the TPS and reconnect it. Is it giving off the wrong voltage when the engine is warm?? Also, my knock sensor code has been on since I've had the swap but I've replaced the actual sensor. So, what could also be the cause of my knock sensor code coming up? I would appreciate any help on this problem. Thanks
