Fender questions
Sup guys...
Just wanted to kniow if anyone knows the steps to remove the driver side fenders from a 91 Civic hatch? I have a dent on the front of it where the corner light goes, and the light won't fit, so I want to take it off, and "try" and at least bang it out enough to where the light will fit. The dent it probably as big as if you hit the car with your fist. Not that big, but it also don't look good, since I also don't have the corner light. Thnx for your help.
I think the Civic is the same as a CRX, and on my CRX theres like 6 bolts on the top under the hood, one behind the driver's side door, u have to open the door to get to it, a screw under the corner light, and I think one bolt under neath the fender... Not sure if the splash gaurd on the bottom is screw into the fender or not, but if it is, u have to unscrew that as well...
Removing a fender is not hard.
Take a look at it and figure it out,DAYam!
If it is the same as a Crx,3 bolts under the hood,2 or 3 which are accessible when you open the door,one by the corner light.It is easy look in those areas,you can figure it out.
That's what I thought, it shouldn't be that hard, but since I'm really new into doing car things, and at my girl's house they call me destructo, I rather get some advise. It never hurts to get advise. Is there anything attached to the fender, aside from the wheel well?
