is there eany way this will work???
im trying to put a 88 crx si 16 valve head on to a 86 crx si block will this and has eany one did this ???????
:dunno: all help in very much appreciated
If you have to ask, you can't do it.
The D16A6 head will require a complete rewiring of the engine harness along with some plug swapping and other electrical-intensive goodness. This is all due to the stock vacuum advance distribuor having a different bolt pattern then the 88-91 electronic advance dist.
A6 head will not work Not on the EW. A1 will.
A1 will.
