head swap
Old Jan 25, 2005 | 10:35 PM
Reason's Avatar
Reason
Default head swap
I have a 89 CRX DX and need just a little bit more HP. I dont care for huge power with this car, I have a Subaru for that. Can I replace the head with one from a SI?
Old Jan 26, 2005 | 12:21 AM
Pete's Avatar
Pete
Civilian
I always thought they had the same head. The only difference is the displacement. Even if the heads are different, I don't think you're looking at noticeable gains.
Old Jan 26, 2005 | 07:49 AM
Kai's Avatar
Kai
Rotorphile.
The heads are the same, aside from the cam and intake manifold/fuel system. They are both the standard 16v head casting.
Old Jan 26, 2005 | 10:13 AM
Exempt's Avatar
Exempt
2 tone Rex
The best swap for that, rather than a head, would be a MPFI swap... Swap out your DPFI (2 injectors) for MPFI (4 injectors) from an Si... Lots of wiring tho, but would be worth it, and give u that extra boost you are looking for...
Old Jan 26, 2005 | 11:19 AM
Running925's Avatar
Running925
Your Powder Coater
does someone make a painless wire harness or conversion for this?
Edit: answered my own question, Hasport sells one, but is there anything cheeper out there!
Old Jan 26, 2005 | 01:14 PM
Reason's Avatar
Reason
Ok, if the heads are the same what about cams for the 1.5? I don't really want to mess with wiring, and I don't trust anyone with a "custom" job. I was hoping it be something I could swap in a day maybe a few hours (with the parts).
Old Jan 26, 2005 | 03:33 PM
Exempt's Avatar
Exempt
2 tone Rex
I honestly dont think itll worth your while... Without the needed gas from 4 injectors, any extra power would go to waste...
Old Jan 26, 2005 | 04:14 PM
Reason's Avatar
Reason
That sux, how much of a difference would I have with a lighten flywheel? Unorthodox or center force?
Old Jan 28, 2005 | 05:15 PM
Kai's Avatar
Kai
Rotorphile.
It's not so much the volume of fuel , it's the distribution of it. Direct port fuel injection systems are much better performing then "wanna-be carburator" style throttle body injection systems.
Old Jan 28, 2005 | 07:47 PM
ED9man's Avatar
ED9man
driver
:chuckles:
I actually know what you mean.
