88 crx hf b16 swap
Old Jan 23, 2005 | 01:17 PM
crxresurrect's Avatar
crxresurrect
Default 88 crx hf b16 swap
i was wondering if my vtec and everything will work with a pm6, or do i have to get another ecu and which one is the best for the b16a swap.
Old Jan 23, 2005 | 03:18 PM
ED9man's Avatar
ED9man
driver
No, unless you know what you are doing never mix and match ECU's with different motors.
You need a PW0 ECU if I am not mistaken if you are planning on getting the B16a out of the EF8/EF9.
If you buy a complete changeover, which is the smartest option unless you want to hunt down a million little parts, you will get the ECU with it.
Old Jan 24, 2005 | 06:09 PM
crxresurrect
i had a pr3 in there and it would run for about 5 mins then all the sudden would just die and when i put the pm6 in it ran and never has died but it is throwing a code 20 which is electronic load detector. so that is why i was asking about the pm6 ecu and if it would work. Thanks
Old Jan 24, 2005 | 06:15 PM
ED9man's Avatar
ED9man
driver
The motor will not run right and VTEC will not work. The D16A6 is a completely different engine.
Old Jan 24, 2005 | 06:19 PM
crxresurrect
i also had a question about the ef8/ef9 what is that. if you dont mind me asking. Thanks for the help
Old Jan 24, 2005 | 07:11 PM
ED9man's Avatar
ED9man
driver
4th CRX SiR/Civic SiR
Old Jan 25, 2005 | 01:05 AM
Exempt's Avatar
Exempt
2 tone Rex
EF is the chasis code for the 4th gen civic and second gen CRX in Japan, the 8 indicates a CR-X SiR, which is the top of the line model, power windows, leather interior, glass top (some of them), b16a engine (160HP), different front end, ect... Just a better over all car, as far as options go, and the EF9 is just the Civic hatch version of the EF8...
Hell, even the JDM Si's (EF7) got alot more options than we did in ours... The DOHC ZC engine for starters... But we get stuck with the crappy SOHC 108HP version of the ZC... :angry:
Old Jan 25, 2005 | 05:33 AM
ED9man's Avatar
ED9man
driver
The seats were half leather/half cloth.
Old Jan 25, 2005 | 08:31 AM
gingas's Avatar
gingas
Yeah, we do get robbed of having the good cars from Japan. The only thing I wasn't aware of was the SiR's came leather seats. Also didn't the SiR's come rear disk & their front suspention was stiffer than the US models. gingas
Old Jan 25, 2005 | 09:48 AM
ED9man's Avatar
ED9man
driver
I think stiffer all around and they had bigger brakes all around and optional ABS among other things we didn't get.
Why do you write "gingas" after every post? We know its you.
