Is there Throttle sensor or is it the timing off?
Old Jan 21, 2005 | 09:12 AM
ajusaf's Avatar
ajusaf
Default Is there Throttle sensor or is it the timing off?
Wondering if my 1990 crx has a throttle sensor or my timing is off b/c after the car is warmed up whether it be on Park or Neutral the RPM go wacky. the car goes to like 2000+ RPM and back down adn then back up until its about to stall but on Drive its normal.
Old Jan 22, 2005 | 06:27 AM
Jigga JJ's Avatar
Jigga JJ
there should be a Tps sensor on the intake manifold(if your rex is MPFI) i cant remember where it is located on the dx models if they have.another thing u might want to do is.remove and clean your eacv
Old Jan 23, 2005 | 09:57 AM
Kai's Avatar
Kai
Rotorphile.
Yes, they have a TPS on the throttle body.
This is not the cause of your problem, nor is the ignition timing.
Old Jan 23, 2005 | 08:55 PM
ajusaf's Avatar
ajusaf
then whats the cause of it?
Old Jan 24, 2005 | 05:59 AM
jlicrx's Avatar
jlicrx
fluctuating idle caused by EACV not working right or could be low coolant level
Old Jan 24, 2005 | 08:25 AM
1fasthb's Avatar
1fasthb
I agree ^
Old Jan 25, 2005 | 11:35 AM
ajusaf's Avatar
ajusaf
i just noticed a problem i will take a pic of it and tell me how to fix it. some stick is getting stuck and not going back to position i have to push it back in place and will go back to under 1k rpm idle. give me a hour to get the pic on
Old Jan 25, 2005 | 05:08 PM
slammed91-hatch's Avatar
slammed91-hatch
could be a number of things...because my car does this and has since i did my swap. it could be a vacuum leak, check all your hoses, could have a leak in your intake mani. gasket, could be the eacv, and is most likely not a timing issue.
Old Jan 25, 2005 | 08:30 PM
S2Kev's Avatar
S2Kev
Sticky throttle? Maybe it needs to be lubricated.
