how do you take off a tranny oil fill plug/bolt if it has been rounded?
this is a bitch. the bolt was in bad shape so a 17mm wrench wouldnt go on. it would just barely get the tip of the bolt. i tried that failed. then i tried a lock wrench or whatever you call it. that failed. then i drilled a hole though it put some broke drill bits in the hole then used the lock wrench. that failed, bits broke everytime. i dont know what else to do now, so i need help i only filled the tranny fluid up the the axels thats the only why i could get the fluid in. so its not even full. but enough to move round the lot i think. so how do you take off the tranny oil plug/bolt if its rounded with a lil hole in it? and one more thing its tight as F**K.
you will have to use a hammer and chisel or big screwdriver
and try to carefully hit it in the same direction as you would to take it off with a regular ratchet and when you get it out just buy one from the dealer good luck. |
did you try using vise grips?? that bolt shouldnt be on there that tight
Originally Posted by teg92
vise grips
yeah vise grips thats what there called. lock wrench thing = vise grips. everytime i try it it slips. man ima snap soon. this is the ex tranny. when i finished my tranny swap i was bout to fill it up and so this happend. ima just use my 4speed bolt if i could get this gay one off.
They also sell special sockets for striped bolts go to your local autoparts store and look for those sockets Im sure those will work, If not you should keep trying with the vise grips
special socket eh. think ima have to check that out.
http://www.sears.com/sr/javasr/produ...id=00952166000
sears sells them |
aye thanks for the site, i really appricieate it. ima go to sears tomorrow. you think they might have it in stock. or ima have to order it.
they have everything in stock
