changing springs
Old Aug 15, 2002 | 03:59 AM
excitid's Avatar
excitid
Default changing springs
Am I right to believe that I will need a spring compressor. I've been searching and some people say yes some say no.
Old Aug 15, 2002 | 04:14 AM
WhiteRice's Avatar
WhiteRice
Yes if you don't want a spring to shoot up your ass!!!
I've heard people not using them and tossing them in the air and letting them just shoot off...but that is hella dangerous.....just spend the extra 10 bucks or whatever and get a spring compressor.
Old Aug 15, 2002 | 02:40 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Yes, use one, people who say you don't need one are dumbasses. Harborfreight.com sells one for $6 or something now and that is the one I used and it worked fine.
Old Aug 18, 2002 | 01:57 PM
92Prelude-Heath's Avatar
92Prelude-Heath
Hey, if you want to have your springs changed you should take it to a shop, if you dont have a compressor because your cars wieght will be pushing down on your springs which could fly off and either hurt or kill you.
Old Aug 18, 2002 | 04:15 PM
RiceBoysDream's Avatar
RiceBoysDream
use your car as the compressor, b4 starting work just pop ur hood and lossen the center bolt thats suronded by the 2 bolts. the main bolt that holds the strut. then just jack up your car and lossen away at whats needed to remove the spring/strut. and their ya go. i didnt need to use a spring compressor for the front of my friends ef hatch nor for the back.
Old Aug 18, 2002 | 06:39 PM
Tony96EX's Avatar
Tony96EX
^ what he said :thumbup:
Old Aug 18, 2002 | 06:56 PM
WhiteRice's Avatar
WhiteRice
do they shoot out to the ground?? Or do they just drop?
I think I'd still get that $15 insurance policy (compressor)!!!!
Old Aug 19, 2002 | 06:13 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
They normally just drop, the key is to let the spring open slowly and controlled, and to compress them slowly and controlled. A spring compressor is a very good idea on higher spring rates though, since they can shift directions and shoot out quicker than OEM springs that don't have as much tension, and above all else, only compress the spring as much as you have to to get it mounted, there's a reason it's called a spring "rate."
If you're still unsure, a spring compressor costs less than chest surgery.
-Harry
AIM: NDcissive
idol4232003
Accord
7
Sep 24, 2007 04:53 PM
loctoday
Do It Yourself
Oct 26, 2004 10:03 PM
SpeedDriven
Aug 28, 2002 10:37 PM
