91 hf crx.....motor???
Old Sep 11, 2004 | 05:40 PM
lime91crx's Avatar
lime91crx
Default 91 hf crx.....motor???
i have a hf with an si motor....i just got a d16z6 so its the same as the si just with v-tec.....that motor needs rebuilt tho....should i rebuild it or get a b16??.....i know there would be a big diff. in hp but it will take most of the winter for me to get a b16...what would you guys do?
Old Sep 16, 2004 | 09:38 AM
turboprelude95's Avatar
turboprelude95
Boost your d16a6 and rebuilt your z6 on the side for it to be a built motor that with boost will have more horsepower than a b16.
Old Sep 16, 2004 | 05:14 PM
ED9man's Avatar
ED9man
driver
B16
Old Sep 16, 2004 | 05:23 PM
lime91crx's Avatar
lime91crx
well i recently helped my friend put a b16a2 in his 94 civic...he didnt need differant motor mounts as in conversion. the ones that came with the motor fit right in. so if i got an a1 would that bolt right in or not
Old Sep 17, 2004 | 03:09 AM
Kai's Avatar
Kai
Rotorphile.
There is no such thing as a B16A1.
At that, no B16A will bolt into an American 88-91. It's not even close, you need an expensive aftermarket mount kit.
If I where you, I'd sell the D16Z6 and save the money for a B18A1 or better. I'm not a big B16A fan myself.
Old Sep 17, 2004 | 06:34 AM
v8guy's Avatar
v8guy
Professor
If you google B16A1 you get about 2100 results. Are you sure about that Kai? I thought the B16A1 was a JDM engine used in the SiR models.
What is better about the B18? The junkyard I go to has like 5 of them. What are they worth?
Old Sep 17, 2004 | 11:14 AM
mistacee's Avatar
mistacee
Zc powered ED9
Yes there is,it is the 1st SiR motor.Altho i have seen it just called the b16a also.It was found in JDM 90-91 Civic SiR/CRX SiR, Integra RSi/XSi i beleive.
Old Sep 17, 2004 | 02:14 PM
Kai's Avatar
Kai
Rotorphile.
Absolutely. It's a misnomer spread by those who don't know any better.
B16A: All first and second generation B16A's.
B16A2: OBD2 del Sol VTEC, 99-00 Civic Si
B16A3: OBD1 del Sol VTEC
It's odd that they skipped the A1, but they did... at least in the home and US markets.
Modern home market engines never end in a number. For some reason importers started calling the first gen "A1" and the second gen "A2," however if you look at the blocks they all simply say "B16A."
I've only seen a picture of a B16A1 stamp, but don't know if it's real or chopped. It may be a euro market engine, who knows.
Higher displacement. They are valued similar to B16A swaps, but you can usually get them cheaper.
Old Sep 21, 2004 | 10:31 AM
turboprelude95
b18's are good torque wise than a b16 is. b18 for boost has more hp and more torque while a b16 boosted has more hp some torque.
