b16a timing belt/flywheel torque specs
swapping a b16a into a 91 si, some of you may remember last thread.
basically need to know TQ specs for bolts involved with timing belt, like tensioner bolts and tensioner adjustment bolts. also the pressure plate mounting bolts (10mm, 12pt).
also having a bitch of a time pulling the crank pulley, tried chain wrench on pulley and pinning flywheel thru bolt holes with screwdriver. sheared screwdriver
new plan, there is a hexagon or octagon shaped cutout on the crank pulley, just like the h22a, anyone know if they make a tool (wrench, etc.) for this to aid in crank pulley removal?
any first hand experience or helms specs would be MUCH APPRECIATED
TIA
~kris
TIA
~kris
