Oxygen sensor..
Old Jul 29, 2004 | 01:07 AM
Reason's Avatar
Reason
Default Oxygen sensor..
89 CRX DX....I just got headers and a highflow cat. What oxygen sensor should I go with? Bosch or NTK?
Old Jul 30, 2004 | 05:23 PM
Pharmacist's Avatar
Pharmacist
Street Corner
get the universal and wire it yourself its only one wire and its all the same... well thats my opinion... its also a difference of 17 to 32 dollars and i think at autozone the universal is a bosch
Old Aug 1, 2004 | 10:19 AM
Benskins's Avatar
Benskins
98 Civic 4dr
i bought the universal one too, i beleive it is a bosch, and was under 20 chux
Old Aug 2, 2004 | 01:09 PM
Kai's Avatar
Kai
Rotorphile.
Either is fine, but I'd rather an NGK over a Bosch myself.
Old Aug 2, 2004 | 02:14 PM
jc836's Avatar
jc836
Want a real Honda one? I have a used spare from my Si that you can buy (e-mail if interested). It fits every header that I know of-the only thing you have to do with the sensor is extend the wire from the it to the original connector (cable should be with header if DC). Otherwise, it is up to you-many threads cover this subject-but the OEM one is going to last the longest.
Old Aug 3, 2004 | 01:17 AM
Reason's Avatar
Reason
That's what I was thinking...
Old Aug 3, 2004 | 09:50 AM
mullinator's Avatar
mullinator
The last time I priced an OEM O2 sensor from Manchester Honda (for a 1st-gen CRX) it cost 178USD. The Bosch ran me $20. There's no way an OEM is going to last 9 times than a Bosch universal.
Here are some tips on R&R. Take some cutting pliers and destroy the body of the sensor such that what's left is short enough to fit inside a deep well 7/8" socket. Some replacement sensors are short enough to fit in the same socket, some aren't. I would suggest trying very hard to source a short one. You can tuck the wire up into the socket and install it that way. If you decide to use anti-seize compound on the threads of the new sensor be certain to keep the sensor tip itself dry. You will ruin the sensor if you don't. -scott
Old Aug 4, 2004 | 06:49 PM
A_PHOBIA's Avatar
A_PHOBIA
dude wtf are u talking about, if you have trouble getting it out heat it up with a torch ,get a set of vice grips and a hammer and go to it.if it still sticks go get a large screw driver/pry bar and break that fu(ker .all it is,is porclyn"sp" its real easy.and yes then put some lube and put the new one in.
