What the hell is this?
Old Mar 7, 2004 | 07:45 PM
JackDaniels's Avatar
JackDaniels
Default What the hell is this?
Today I dropped the tranny to put my SPEC stage 1 clutch in. I noticed there was a line coming from the firewall to the tranny. It look like some kind of temp sensor. Can anyone tell me what it is and if it is important, thanks.
Old Mar 7, 2004 | 07:47 PM
Daniel's Avatar
Daniel
The only sensor's I know of that go in Honda manual transmissions is the reverse sensor. Are you sure it's not your clutch cable?
Old Mar 7, 2004 | 08:00 PM
JackDaniels
Im pretty sure it wasnt.
Old Mar 8, 2004 | 04:33 AM
kd5dbl's Avatar
kd5dbl
[Edit]
Just removed my comment... because I noticed Daniel beat me to it...
Old Mar 8, 2004 | 07:35 AM
Paul's Avatar
Paul
Eater of Rice
what about the VSS
Old Mar 8, 2004 | 02:45 PM
Kai's Avatar
Kai
Rotorphile.
Sounds like the VSS, if not the reverse switch. Most likely the VSS.
The clutch cable looks nothing like a temp sensor, so I doubt it was that.
Old Mar 9, 2004 | 08:08 AM
JackDaniels
Yes, I am pretty sure the clutch cable was taken out(a bunch of people working on it). What is a VSS?
Old Mar 9, 2004 | 09:05 AM
sick79's Avatar
sick79
vss=vehicle speed sensor.
Old Mar 9, 2004 | 02:13 PM
Kai's Avatar
Kai
Rotorphile.
Basically, it is a line that goes from the transaxle up to the speedometer. There is a little gear on the end of the cable, inside the transaxle, that spins with the trans gears and the speedo converts that into a MPH reading.
Old Mar 11, 2004 | 10:20 AM
menappi's Avatar
menappi
i dont think efs came with vss, they just have a cable driven speedo with the gear
