Need info on axles
Old Feb 25, 2004 | 07:13 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Default Need info on axles
Okay will all the years axles fit in each tranny? 88-91 axles into any of the 88-91 trannys? or does the 88 have to go in the 88 tranny and so on? let me know!
Old Feb 25, 2004 | 07:46 PM
jaje's Avatar
jaje
HC Racer H5
see attached
File Type: jpg
Old Feb 25, 2004 | 08:10 PM
ZiviCase10287
RacinMasonC
correct me if i'm wrong but then only 89-91 axles will work in my 90-91 ZC tranny? cuz the 88 is 21 splines instead of 20 like the other trannys?
Old Feb 25, 2004 | 08:15 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
your local junkyard would know interchangeablity most of the time
Old Feb 26, 2004 | 04:47 AM
jaje's Avatar
jaje
HC Racer H5
i think that is true...honda played around with the drivetrain with different clutch configurations, axles, etc.
Old Feb 26, 2004 | 07:40 AM
ZiviCase10287
RacinMasonC
oh ok, thanks
Old Feb 26, 2004 | 06:14 PM
jlicrx's Avatar
jlicrx
any 88-91 CRX/Civic axle will fit into any 88-91 CRX/Civic transmission - the difference is at the hub end - the CRX HF and Civic STD have smaller hubs - none of the 88-91 CRX/Civic axles will fit the ZC transmission - it uses the larger diameter 90-93 Integra axles with a ZC (and only ZC) intermediate shaft - the 20 and 21 splines are on the input shaft of the transmission which goes into the clutch disc - has nothing to do with axles - all 88's have 21 spline input shaft and 89-91's have 20 spline
Old Mar 9, 2004 | 10:19 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
Basically any year, newer than 90, axle will fit any 90+ civic with the d seiries. Thats what i got from the attachment
keefungliu
15
Feb 11, 2004 03:50 PM
Chin
4
May 2, 2003 08:45 PM
SiR-DC2
Dec 10, 2002 06:32 PM
whiteciv
Engine Swaps, Tech & Tuning
7
Aug 24, 2002 04:28 PM
CivOnDubs
Jul 9, 2002 07:02 PM
