What fuel injector cleaner to use???
Old 02-20-2004, 06:57 AM
honda1998civic
honda1998civic's Avatar
Default What fuel injector cleaner to use???
Just wondering what fuel injector cleaner you guys would reccomend using? Would it really matter or would the cheapy super tech work?
Old 02-20-2004, 07:03 AM
Magik
Magik's Avatar
Personally...usually any place I go and think to pick up injector cleaner carries "STP" injector cleaner...that is typically what I use...I don't think it matters what you use, just THAT you use it.
Jason.
Old 02-20-2004, 09:39 AM
bustah49
Mr. Motorhead
bustah49's Avatar
here in s. central pa. we have napa auto stores. they carry this stuff called sea foam. that shit works..it is unbelievable. see if you can find it
Old 02-20-2004, 01:58 PM
Kai
Rotorphile.
Kai's Avatar
I don't bother with that stuff. If anything, use the Techron additive made by Chevron.
Old 02-20-2004, 02:04 PM
S2Kev
S2Kev's Avatar
I agree. But it doesn't clean your injectors as well as doing a real injector clean which is more than just putting some additive in your tank.
Sea foam is used to decarbonize your engine. It doesn't clean your fuel injectors.
Old 02-20-2004, 02:35 PM
bustah49
Mr. Motorhead
bustah49's Avatar
they have a whole display setup....not just for the shit to take the carbon off of yer valves, but fuel injector cleaner as well.
here ya go...mr. know it all
http://www.seafoamsales.com/motorTuneUpTech.htm
#1 in uses
injector cleaner....
and just for you....look at my avatar
Old 02-20-2004, 03:02 PM
Kai
Rotorphile.
Kai's Avatar
Real injector cleaning is all I do.
I don't see how anyone can believe a little bottle of chemicals, mixed in 13 gallons of gas is going to magically clean their injectors. :chuckles:
#1 in uses
That site only lists applications for Diesel and small gas (like weedwacker) engines.
Old 02-20-2004, 03:13 PM
kd5dbl
kd5dbl's Avatar
My question is how often to use STP? I have been waiting until I either get some misfire or noticable lack of power/fuel economy. Do you guys have a (reasonable) interval to do it as preventative maintenance?
Old 02-20-2004, 10:04 PM
A_PHOBIA
A_PHOBIA's Avatar
[QUOTE=Kai]Real injector cleaning is all I do.
QUOTE]if you use a bottle of 104+ octane on 1/4 of a tank it will kick in .
only drive on it for like 10-15 miles then fill her up.i use the outlaw octane booster.its the same thing as injector cleaner.
Old 02-20-2004, 11:47 PM
S2Kev
S2Kev's Avatar
#1 in uses
If you're just adding it into your fuel then it doesn't work well in my opinion, unless if you use it in conjuction with a fuel injector cleaning machine.
Quick Reply: What fuel injector cleaner to use???
