HELP: broken fuel rail stud
Old Feb 1, 2004 | 11:31 AM
shawn_crx8891's Avatar
shawn_crx8891
Default HELP: broken fuel rail stud
can the studs in the intake manifold for the fuel rail be replaced? i broke one and i really don't want to buy a whole new manifold. i haven't tried anything yet, so any help is appreciated. thanks.
Old Feb 1, 2004 | 01:11 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
You can buy stud removers that will unscrew them supposing you have enough of the stud left. If not than you can buy bolt extractors, the Snap-On one works really well, they are actually the only company that I see making any that are worth a shit.
Old Feb 1, 2004 | 02:15 PM
shawn_crx8891
so the stud is just screwed down into the manifold? it's just the top that broke off so there is plenty left, just not enough for the nut to thread on. where would i find a stud remover, and do you know a price range? thanks.
Old Feb 1, 2004 | 02:48 PM
DhRacingJosh's Avatar
DhRacingJosh
It's easy to get them off without a stud puller, just get some vice grips, clamp it good, and break it loose, then it should unscrew very easy. You can find stud pullers at any store that carries tools and sockets. Im not sure which size that would be but I know it's smaller then a 5/16.
Old Feb 1, 2004 | 02:52 PM
shawn_crx8891
ok thanks. i'll try that or maybe notch the top with a dremel and unscrew it with a screwdriver if it is tight. would you happen to know the size of the stud so that i can buy one before taking my fuel rail off? thanks.
Old Feb 1, 2004 | 03:07 PM
DhRacingJosh
I can check but Im not at the shop right now, so I dont have the stud puller. Maybe someone else knows off hand.
Old Feb 2, 2004 | 06:45 PM
Kai's Avatar
Kai
Rotorphile.
I've pulled a couple broken fuel rail studs with needle nose vice grips before. Easy.
Old Feb 2, 2004 | 07:30 PM
shawn_crx8891
thanks for the suggestions, i used vise grips and it came right off. thanks again.
VTECNLUDE
Sep 17, 2003 09:45 AM
Jeice
Apr 8, 2003 06:47 PM
SIGMA CHI GUY
Mar 13, 2003 05:35 PM
jaje
News & Rumors Archives
12
Dec 26, 2002 08:41 PM
