alarm wiring help needed
hey i recieved this alarm, and i thought it would be pretty simple to put in, but the wiring diagram looks weird. i dont know where ANY of the wires go. i have a 91 dx with no power anything. all i want is the shock sensor hooked up, and my parking lights to flash, maybe a dome light, and the alarm to just be a normal alarm when bumped, so a basic alarm. here is a picture of the wiring, coudl anyoen explain as much as they know of where i shoudl hook these wires up???
Here is the diagram for car, hopefully :
1988-91 Honda Civic Security Information
Constant 12V+ White ---->>>Ignition Switch Harness
Starter Black/White ------->>>Ignition Switch Harness
Ignition Black/Yellow ------>>>Ignition Switch Harness
Accessory Blue/White ----->>>Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White ->>>Brake Switch
Trunk Pin Green/Black (-) -->>>Harness from Dash INDICATOR
Parking Lights Red/Black(+) --->>>Fuse Panel
Head Lamp Red/Blue ------->>>Fuse Panel
Hood Pin n/a
Factory Disarm n/a
Door Trigger Green/Red (-) ->>> Driver's Kick
Door Lock Green/White (-) ->>>In Driver's Door at Door Lock Module
Door Unlock Green/Red (-)
Horn Wire Blue/Red (-) ----->>>Steering Column, use Relay
I got this from the12volt.com, go overthere, someone should be able to help you more.
here is the link http://www.the12volt.com/installbay/
Anyway, from my understanding:
Since honda uses negative door trigger you should hook up the door trigger this way:
Door Trigger Green/Red (-) ----- Side door neg. (I/P-)
Constant 12V+ White ----- 12v (I/P)
Parking Lights Red/Black(+) ---- Light (o/p +5A) don't know why there is two lights output on your diagram
This is all i can think about right now. I'll check on it again tomorrow. Do yourself a favor, buy a multimeter (digital) and double check the wiring for car
Peace
Hood Pin n/a
Factory Disarm n/a
Peace
hey thanks alot, i got a voltameter, what should i do with that? lol.when i install the alarm, do i just .. tape the wire from the alarm into the coresponding wires? or what?
what about the wire that says ACC that goes to ..the ignition? where woudl i hook that up. and theres two 12V wires, one has an (i/p) whats that mean? one has a thick yellow wire (the one that goes to the relay)..ack sorry all the Qs, i just want to get this in. thanks .
