Surging?
Old Feb 11, 2004 | 03:14 PM
S2Kev's Avatar
S2Kev
If you're looking at the check engine light blinking then you're reading codes wrong. You're supposed to look at the LED that is on the ECU. It'll pulse one time when you turn the ignition and once whe you turn the ignition off. If the light blinks anything in between those 2 pulses, it is throwing a code.
I would actually check the idle air control motor, there maybe carbon build up in those 2 passages. It is located behind the intake manifold and is bolted down by 2 bolts, there are 2 hoses coming out of it. Do not remove those hoses. Get some carb cleaner and spray it in there and also in the holes into the intake manifold.
Old Feb 11, 2004 | 06:29 PM
Jigga JJ's Avatar
Jigga JJ
no i wasnt watching the check engine light.i was refering to the ecu......i jus pulled back the carpet and watched da light blink is all....hmm....its wierd....i still havent checked my voltage accross my EACV as yet.but im thinkin if it was faulty it would have set off the vode for that already.ill see wut u r talkin about
