Temperature Sensor
Old Jan 9, 2004 | 06:06 AM
Magik's Avatar
Magik
Default Temperature Sensor
I had a diagnostic test done yesterday and one of the things they told me I needed was the temperature sensor that controls my "fan", as the fan behind the rad is running constantly. Problem is I don't have a freakin' clue where that is? Is that actually what it is called...just the temperature sensor or is there another name for it?
Thanks for the help...
Jason
Old Jan 9, 2004 | 06:48 AM
jlicrx's Avatar
jlicrx
it is the coolant temperature switch - it is located on the back of the engine next to the oil filter - has 2 wires to it, a yellow with green stripe and a black
Old Jan 9, 2004 | 07:22 AM
crxb16er's Avatar
crxb16er
yep the 2 wires are supposed to connect to 2 little sensors right above the oil filter, feel around and u'll notice them there is 1 other wire back there to another sensor, (the 2 wires are the temp sensor), the radiator thermo sensor is the sensor on the passenger side of the block going to the ecu, its a plug type sensor that costs about 20 bucks to replace at most import parts stores.
Old Jan 9, 2004 | 07:23 AM
Magik's Avatar
Magik
That is the one that would keep the fan running constantly?
Jason
Old Jan 9, 2004 | 08:12 AM
jlicrx's Avatar
jlicrx
Jason
Yes, that sensor tells the fan when to turn on - that is its only function - the other sensor right next to it with one wire is the oil pressure light
Old Jan 9, 2004 | 08:23 AM
Magik's Avatar
Magik
Super! Thanks a lot for the help!
Jason
Old Jan 9, 2004 | 10:43 AM
Magik's Avatar
Magik
All Honda told me was that I needed a new 'temperature sensor'...
So do I need the "switch" or do I need the "sending unit"...because one is $50 (switch) the other is $20 (sending unit)...??? I ask cause I just called a different place other than Honda and that's what they asked me...I didn't know what to tell them.
They told me I needed this because my fan 'never' shuts off...even when I am turning the key to start the car (II), after the first click the headlights and the fan start up and then the engine...the fan never stops...
The engine is a 90' d15b1 will the sensors from my old B2 that I just pulled out work with this engine?
Jason
Old Jan 9, 2004 | 07:42 PM
Magik's Avatar
Magik
Anyone?
Jason
Old Jan 9, 2004 | 09:49 PM
jaje's Avatar
jaje
HC Racer H5
there's only one way to find out...try the old sensors (they are free)...as for the switch / sending unit question i don't have my helms near by to figure it out
Old Jan 9, 2004 | 11:30 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
Anyone?
Jason
They will probably work, but it's possible that the temperature may be different. You can compare the part numbers at http://www.slhondaparts.com/browse.asp .
