bolt pattern/offset question
Z20 H8R
ok since i got the knuckles of a 93 integra in front....and 89 crx in the back are my bolt patterns the same? 4x100 all around?
what exactly is the offset on rims?
also will either 245/45 16 or 225/45 16's fit on a crx? i need meat....
I'm RICK JAMES, bitch!
You have to know the width of the rim to know how fat a tire you can put on it. And anything more than 205 will rub the rears. My rims are 7inches wide and fit a 205mm wide tire and that is as big as you can get on a 7 incher.
7 inches should be 175mm, so you can fit a fat tire on a rim that is smaller. But there is of course a limit.
As for offset +45 should be correct. Or if you put on a really wide rim you can go +40 but I wouldn't put a giant rim on your car, its going to create issues.
Z20 H8R
k here is the specs on the rims..
Size: 16", Bolt Pattern: 4x100, Offset: 40mm
will those fit my acura and my honda knuckles? and how fat can i go for a tire.....as much meat as possible..
