JDM D15B Vtec Swap in 88CRX HF
I have an 88 CRX HF. I am putting in a JDMD15B Vtec engine. I want to use my existing wiring harness and ECU. The plugs on the Vtec are different than the stock wiring harness. Does anyone know of a kit or web site or if someone sells a kit to wire up the stock wiring harness to the plugs on the JDM 15vtec?
http://www.hasport.com/Products/ECUS.htm
this is where i got my b16 harness. they might have what you want. |
most of the clips fit if you are saying obd0. I have done that swap in a hacthback. If you need help or parys let me know. It all depends on if you are gonna stay obd0 or convert or obd1
if you are staying OBD0, you don't want to use your HF ECU - get a Si PM6 or 88-89 integra PG7 - you must use your HF harness and either add the wires for VTEC and knock sensor or get the EFSI-VTEC sub-harness from Hasport ($75) - if you want to switch to OBD1 using the P28 ECU, you need to convert like this: http://www.geocities.com/kurtsi_on/page8.html
