Clunking... bad struts?
Old Nov 13, 2003 | 08:22 PM
leechy's Avatar
leechy
Default Clunking... bad struts?
Well, at first I thought a rotor was warped, because whenever I would put the brakes on, the steering wheel would shake and something in the front end would make a clicking-type noise. I replaced the rotors and the pads, but the noise persists. What could this be? Worn-out struts? Some bushing or something gone? Anyone else experienced this before?
Old Nov 13, 2003 | 09:46 PM
420J's Avatar
420J
It could be a number of things. Bad sway bar bushing or sway bar end links. Is the car lowerd? Get under it with a light and start looking around and pulling on things to see if anything is loose. Bad wheel bearing maybe...
Old Nov 13, 2003 | 10:14 PM
S2Kev's Avatar
S2Kev
Does it click when your're turning or just when you brake?
Old Nov 14, 2003 | 11:02 AM
Bogatyr's Avatar
Bogatyr
leechy,
Try the bounce test to see if you can isolate the noise location any better. As 420J mentioned, get underneath there and try to wiggle things...nothing should move by hand.
Bogatyr
Old Nov 15, 2003 | 05:47 PM
leechy's Avatar
leechy
It clicks when i hit the brakes or when i'm going over bumpy roads, i can notice it too. My car isn't lowered at all. I'll take the front wheels off sometime and check out the bushings and stuff..
