b16?
Old Oct 29, 2003 | 11:58 AM
90hbvtec's Avatar
90hbvtec
Default b16?
has anyone recieved a motor from like any of the jdm suppliers...osakajdmmotor,hondamotoroline,nippon, ETC...well i got mine from osakajdmmotors.. and when i got my motor it was clean and all but there was like this oil line from the drain plug of the oil pan instead of a solid plug this plug had a steel line in the drain plug. and there is another steel oil line looking thing connected to some sensor/conector.. ??.. i jess hope my motor was not turbo charge, i jess hope they had this oil cooling system from japan .... has anyone gotten a motor like that..?..or heard of something liek that let me know..thanks and what should i do with the line on the sensor/connector..?
Old Oct 29, 2003 | 02:25 PM
Kai's Avatar
Kai
Rotorphile.
It sounds like someone was running a turbo or an oil cooler, most likely an oil cooler if it has the stock exhaust manifold on the front. The other line is probably a T off of your oil pressure sending unit to feed the cooler, and the plug line is the return.
That's kinda weird though, an oil cooler is completely unnessicary on a B16A.
Old Oct 29, 2003 | 03:25 PM
crxb16er's Avatar
crxb16er
LOL good luck, i honestly mean that best of luck. LOL
Old Oct 30, 2003 | 09:04 AM
1fastercrx's Avatar
1fastercrx
you screwed either way. Send it back with a lot of bitching
