axels
Old Oct 9, 2003 | 10:18 AM
rex03's Avatar
rex03
Default axels
what axels do i use for a crx hf with a jdm b16a i wanna know if you can just buy one or you have to make it custome or what
Old Oct 10, 2003 | 07:29 AM
jlicrx's Avatar
jlicrx
i assume that the hubs were swapped from HF to DX or Si? If so, and you have S1, J1 or A1 transmission, use 90-93 Integra axles - if you have Y1 transmission, then you need custom axle on the driver's side - the intermediate shaft is longer
Old Oct 10, 2003 | 09:37 AM
LIL_G's Avatar
LIL_G
no the hubs werent swaped. when i bought the crx i already have a b16 in it with axels and runs but now the joint is getting ready to break so thats why i need to figure out what axel i need to get . I have a j1 tranny in it now . if iuse the 90-93 tg axels will the outer joint fit the si or dx ,or should i just go ahead and get the 90-93 teg hubs and do it that way. im guessing the guy that had the car built had custom axels built to match up with the hf? if you could give me some more suggestions that wouldhelp thank
Old Oct 10, 2003 | 11:09 AM
crxb16er's Avatar
crxb16er
if uve got axles in it now, take one out and part match it, ur nuckles and hubs would have had to be changed due to the fact that the hf and std hubs will not work with the b16 at all.
Old Oct 10, 2003 | 12:28 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
HF knuckles have 23 spline hubs. All Integra axles are 26 spline. So your knuckles must have been swapped out.
