TCS indicator on TL
Maybe one of the sensors has gone bad. This is the first I've heard so you better take it back to the dealer and let them check it out. Or it could be a short causing the TCS light to come on intermittenly.
My tcs light came on plus my engine light. lugkly i have a snap-on modis scanner. the egr passages was clog. It might be the same thing. change your egr gasket, and clean the passages. use carb bleaner to get the carbon off. You might have take the valve cover and clean the passage that leads to the egr. this will take 4-5 hours.
