Lock not working
Old Feb 4, 2008 | 03:31 AM
cmccaffe81's Avatar
cmccaffe81
Default Lock not working
my lock on my drivers side door is not working unless I manually push it down, I can push the button to unlock but not lock- some how this got screwed up while i was taking the panel off the door but I have no idea how because i couldn't even get that wire off! Any ideas? Any way to fix this?
Old Feb 4, 2008 | 11:04 PM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
With your door panel off, does it work? If it does, then you probably is either didn't install the door panel back on correctly or a wire in pinched. If not, then your actuator probably needs to be replaced.
Old Feb 5, 2008 | 08:42 AM
cmccaffe81's Avatar
cmccaffe81
Default ?
If my actuator has to be replaces would unlock work?
Because I can us the unlock button on the door and on my remote
Old Feb 5, 2008 | 12:08 PM
AcuraTL's Avatar
AcuraTL
Well, sometimes an actuator can only go one way if it is broken. Lets say it can only push (unlock) and not pull (lock).
Old Mar 16, 2008 | 08:12 PM
hotdogal's Avatar
hotdogal
Default Where is the actuator?
Where is the Actuator? What does it look like? I have the exact same problem in my 95 Civic.
Old Mar 16, 2008 | 08:17 PM
AcuraTL's Avatar
AcuraTL
Take off your door panel and you will see the actuator. It is usually in black and have 2 wires coming out of it and it connects to the door lock.
