ABS troubleshooting help needed
Old Jan 27, 2008 | 05:35 PM
jdem3's Avatar
jdem3
Default ABS troubleshooting help needed
I have a 1998 TL with an ABS problem. My ABS light is on and I need help in fixing it.
Acura told me the brain was bad, I replace two different control modules and it did not fix the problem. Now I am checking the sensors. I have checked the resistance on each wheels sensor and they are not consistent so I can’t tell if one of them is bad.
Passenger front at 200ohms on the meter .78 ohms
Passenger rear at 200 ohms on the meter .78 ohms
Drive front at 200 ohms on the meter 180 ohms
Driver rear at 200 ohms on the meter 192 ohms.
Can some one tell me why there is a difference between the two sides of the car and tell me what I should see.
I would also like to get any additional guidance or direction for fixing this problem.
Thanks,
Jim
