2004 Acura tl SRS light stays on...HELP!!
Old Oct 11, 2007 | 06:09 PM
jerrfoxx04tl's Avatar
jerrfoxx04tl
Default 2004 Acura tl SRS light stays on...HELP!!
My SRS (supplemental restraint system) light is on and I've tried doing the reset but the light stays on. The dtc is coding 75, driver side airbag problem, it has 4 wires going to the steering wheel airbag, how do I check the airbag on the steering wheel to see if it is good? The seat has a 2 wire connector, I can check the one under the seat 2 wire connecter. I have a 2.4 resister to check the air bag. The seat airbag checks to be good. Any ideas....HELP!!!!
Old Oct 13, 2007 | 02:33 PM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
There's obviously a problem with your airbag or else the SRS light would not come back on after you try to reset it. Isn't your car still under warranty?
