How to Retract Rear Caliper Piston?
Replacing rear brakes and rotors on 97 TL 2.5 L: How does one get the piston in the rear calipers to retract so that there is enough clearance to fit the caliper assembly over the new rotor and brakes? I tried to push the brake piston back into the caliper (using a c clamp, then a mod reversing a steering wheel puller into a pusher!) with absolutely no luck...it would not budge. Opening the bleed valve and applying (a great deal) of force to the piston did no good either, there is something preventing the backflow of fluid in the brake line. Looking at the service manual i did not find any help. Thanks in advance. cd
Lord Vader Moderator
If you cannot retract it with a c-clamp with the bleeder valve open, then you might have a busted piston. Does any fluid come out when you open the bleeder valve? Are both of the pistons not retracting?
Yes, they screw in clockwise, thus the slots on the piston. If you have used an extreme amount of force on the piston with the C-Clamp, or a press, it may be too late for that caliper. A file, large screw-driver, or something of that sort works well.
Here's a tip with a large screw-driver: Place it so that you're using it as a pry-bar, instead of a screw-driver.
