Timing Belt Replacement 2000 3.2Tl
Old Sep 27, 2007 | 03:55 PM
orphy15's Avatar
orphy15
Default Timing Belt Replacement 2000 3.2Tl
I do not own a manual so don't tell me to go there but how often do I need to replace the timing belt? I read a bit it seems 90K but wanted to double check.
thanks
Old Sep 27, 2007 | 05:23 PM
orphy15's Avatar
orphy15
on Acura it states 105k or 7 years but is it necessary? How will i know if its going or will i?
Old Sep 28, 2007 | 07:51 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
You can inspect it yourself for wear and tear but if you are, for example, going at highway speed and it snaps, there goes your engine.
Old Oct 2, 2007 | 12:06 PM
orphy15's Avatar
orphy15
Is it a large job for a dealer? I hear that it involves lifting the engine to replace the belt. thanks again
Old Oct 2, 2007 | 01:38 PM
AcuraTL's Avatar
AcuraTL
I don't know about lifting the engine but I know it is a big job and you should also replace the water pump when you do the timing belt.
Old Oct 4, 2007 | 05:49 AM
orphy15's Avatar
orphy15
thanks for the advice!
Old Oct 4, 2007 | 10:24 PM
nhantech's Avatar
nhantech
there is no lifting of the motor1 all you are doing is removing the side motor mount, which is at the front of the motor. you can replace the water pump but i have very rarely seen them leak. that is all up to you. i use to work for a dealership. hope it helps.
Old Oct 24, 2007 | 09:16 AM
orphy15's Avatar
orphy15
thanks again!
