Mileage
I have a question about my 97 CL. I have 177K miles on it and it is running awesome, not burning any oil. I have had the timing belt changed and the waterpunmp replaced. Recently I discovered that there is a little leakage coming from the engine and I assime it is the main seal. Has anyone had the seals replaced on their engines and what did it cost them and is it wort it or should I drop a used motor in it? I hate to do the latter since my engine is still quiet as a kitten!!!
Thanks
Thanks
The leak is coming from under the timing belt cover and it is slight. The car has not missed a beat and continues to perform well. If I can get the seals changed I would be more inclined to do that if it is financially feasible. This car is awesome and it is going to have to be pryed away from me.
...another issue, I had a CEL and had it checked I was told the EGR Valve and the Position 2 O2 sensor needed to be replaced. I reset the ECU (disco'ed the battery) and the light went off. 24 hours later the CEL came back on, any suggestions?
Thanks
Thanks
Replace the EGR Valve and Positino 2 O2 sensor.
Well, it was good while it lasted. I have changed the EGR Valve and cleaned everything but my CEL keeps coming on with the same code. Anyone have a clue? My gas mileage has not degraded and neither has the performance.
