no lights on the dash!
Old Sep 26, 2006 | 08:49 PM
Accord51's Avatar
Accord51
Acura-FFXI
Default no lights on the dash!
i just installed a pioneer deck in my 02' tl-s and it soudns great but no sub, but thats my problem. for some reason my dash lights will not turn on, any of them. i have a navi, that wont dim when the head lights turn on and my rear tail lights wont turn on either. they were working when i put the deck in but after about an hour of driving around, the lights went out....also my battery seems to not want to keep a charge however the eye on the battery is still green.
Old Sep 27, 2006 | 07:09 AM
t3t4delsol's Avatar
t3t4delsol
does the deck stay on when the key is out? does the deck hold its memory
Old Sep 27, 2006 | 08:24 AM
Accord51's Avatar
Accord51
Acura-FFXI
the deck turns off and stuff, it holds memory.... just noticed when I used my stock alarm the front curtsey lights didn’t flash, yeah, those now don’t turn on either when I turn on my head lights...I checked all the fuses that I could find and they seem ok.
Old Sep 27, 2006 | 08:29 AM
t3t4delsol's Avatar
t3t4delsol
did you facory headunit have an alarm on it? antithief deterant system?
Old Sep 27, 2006 | 10:19 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
Well, try taking your Pioneer deck out and see if everything comes back. My guess is that you probably switched some wires around, like hooking up the ignition wire directly to the battery, draining the battery. Or some live wire is touching metal and shorting out things.
Old Sep 27, 2006 | 10:58 AM
Accord51's Avatar
Accord51
Acura-FFXI
the stock deck did have an anti-thft thing but like i said, after i put the deck in, everything was working. i tried taking out the deck but it's still having the same problem. i really dont want to bring it to acura, they will charge me my left nut just to look at the thing...
Old Sep 27, 2006 | 11:46 AM
t3t4delsol's Avatar
t3t4delsol
if you look at the wiring harness for the car to the unit follow all of the leads for the wires and make sure if there is a lead on one side it continues through the harness to the other clip, im taking about the actual plug in clip, because some cars have different wiring harness made for the same model, possible becuase you have navi,
Old Sep 27, 2006 | 06:02 PM
Misa's Avatar
Misa
Pic Whore
check your fuses?
Old Sep 27, 2006 | 08:06 PM
Accord51's Avatar
Accord51
Acura-FFXI
I checked the fuses on the driver and passenger door side also the ones under the hood. Everything seems fine but I don’t see a fuse for my dash lights or my tail lights. I used a wiring harness and just plugged it into the stock harness. Everything worked just fine; I didn’t have to splice any wires. Just no sub, I’m really stumped...
Old Sep 28, 2006 | 12:11 AM
AcuraTL's Avatar
AcuraTL
Did you try to put new bulbs in and see if somehow they got burnt out?
