acura cl 3.2 2001
Old Sep 21, 2006 | 08:11 PM
snb's Avatar
snb
Default acura cl 3.2 2001
One of my low beam headlamps just flickers but does not fully light up. Does this mean that the bulb should be replaced or is it another problem? The manual discourages owner replacement of low beam lamps because of a possible electrical discharge. Is there a way to replace the lamp myself without getting shocked?
snb
Old Sep 22, 2006 | 11:14 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
It could be the bulb or it could be the ignitor. Just disconnect the battery so you won't get zapped.
Old Sep 23, 2006 | 08:18 PM
snb's Avatar
snb
Default Acura Cl Headlight
Thank you for the information. I was able to replace the bulb but that does not seem to solve the problem. The bulb flickers. When I try the high beam only the left one lights up. Both of the high beam bulbs are good and both of the low beam lights are good. Could the igniter be the problem? If so is it user replaceable?
Old Sep 23, 2006 | 11:11 PM
AcuraTL's Avatar
AcuraTL
I believe the ignitor is a plug and play module, so it shouldn't be that difficult to replace.
