99 cl 3.0 no-start
Old Sep 7, 2006 | 01:11 PM
blackwalls81's Avatar
blackwalls81
Default 99 cl 3.0 no-start
please help......
would a cl 3.0 not start if tdc sensor 2 was bad... tested and no resistance...... possible open circuit or bad sensor also have tested tdc 1 and ckp sensors they test fine... have replaced distributor rotor and plugs
Old Sep 7, 2006 | 06:07 PM
simplyredvw's Avatar
simplyredvw
What exactly is the car doing that would make you think the TDC sensor is bad?
Old Sep 7, 2006 | 07:58 PM
blackwalls81
thanks for the reply simplyredvw
car just cranks and won't start seems like it wants to for a second then nothing
checked all fuses and wiring
changed fuel filter
good fuel pressure
also tested ignition coil and module they are ok....
problems started a week ago when car had been running for a while turned it off for a few 5 maybe 10 min and wouldn't start again replaced cap rotor and plugs car started but ran terrible missing on cylinders 2 and 4 for a short time then turned it off (didn't want to damage cat) tried to start it a short time later and would only crank had it towed to the shop they sprayed starting fluid in it and it fired right up ran great no missfiring drove it arround for awhile got gas started up fine after refueling drove arround awhile longer then parked it overnight next morning wouldn't start only runs on starting fluid for a few seconds then stalls
Old Sep 8, 2006 | 12:44 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
If the TDC sensor is bad, it would cause misfires and of course when your is misfiring, it would be impossible to start.
