engine miss
Old Sep 1, 2006 | 04:29 PM
ajth87's Avatar
ajth87
Default engine miss
i have a 93 vigor and sometimes when i am at a light i will feel a jump type feeling come from the car, the idle will jump down then back up to normal in like a second. sometimes it only does it once and sometimes it does it a couple times a few seconds after one another.. and when the car is warming up, the idle goes down then back up a few times, not fluctuate but goes down some then back up to where it is warming up.. any help.
Old Sep 2, 2006 | 12:46 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
Do you have your A/C on when it is doing this? If so, it is just the compressor kicking in/out. If not, do you hearing your engine misfiring? Does it do it once it reaches normal operating temp.? Did it start recently?
Old Sep 2, 2006 | 11:42 AM
ajth87's Avatar
ajth87
it does it when the engine is warm yes... i know that i need a purge control solenoid valve because it is broken but i am not sure if that could cause the miss...there is a vaccum hose that connects to this valve that isnt connected because it is broken. any other possibilities.
Old Sep 2, 2006 | 04:06 PM
AcuraTL's Avatar
AcuraTL
Just to minus the troubleshooting, you should replace whatever that needs to be replaced and then diagnose. Did this happen recently?
Old Sep 2, 2006 | 04:32 PM
ajth87's Avatar
ajth87
well it started the same day i started driving the car.. just a lil background info.. i bought the car with a bad motor for real cheap.. i had the engine replaced with another used engine.. the car runs great when it comes to driving, the power, performance.. it is just that one skip that i have.. yes this is within the past two weeks so recently.. this coming week i am going to have the sensor changed and then i will go to acura and have a full diagnosis of the car to see what, if any, problems do i have.
