R&R Replace door panel trim, arm rest
My trim is damaged and I purchased a new one. I have the panel loose except for where the handle latch is. I removed the button cover for the small screw behind it and I have the lower screw in the arm rest removed and all the plastic clips. However, I can't get the trim around the door handle to come off. What's the trick ? Thanks, Paul
more info
