Radio Code???
Old Feb 19, 2006 | 10:50 AM
matt_19's Avatar
matt_19
Default Radio Code???
I have a 1999 Acura 2.3cl and i was changing the fuse for my lights and i pulled out the radio fuse by accident and now my stock radio won't work...When i turn it on it says i need a code. Does anyone know where to get the code from??
Thanks,
Matt
Old Feb 19, 2006 | 10:34 PM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
Do a search first, because this topic had been discussed many times. Look inside your owners manual/glove box to see if you have a card with the security code on it. If not, you will need to pull out the factory deck and get the serial number to your dealer in order to get the code.
Old Feb 22, 2006 | 04:24 PM
jayz98's Avatar
jayz98
w0rd. Each radio code is different for each car. That is across the board, accord, civic, CL, etc.
TL has it right. If there is nothing written down as the radio code inside your owners or matience manual, you will have to go to the dealer with your serial number.
Worst case, they will just reprogram and set a code for you. They might charge you an hour of labor for that.
